I need to be able to save a JPG of a frame at a specific time index from MKV files. What tool will do this? I could do a screen capture and cut out the video portion in a paint program but I need to do this for a ton of files so I'm looking for something more automated than that.
Is it the same frame (time position) in each clip ?
Most players can save a frame, as can virtualdub, however automating the capture of a particular frame would be more difficult.Read my blog here.
Different time in each clip. I want to be able to create meaningful thumbnails for icon display on a HTPC and I would have to take the captures manually at various times to achieve that... the automatically generated ones from 10s in or whatever are kind of worthless. I have avidemux for editing but I don't see a way to capture a single frame in that. I also have a couple different players and neither has any facility to capture frames built in.
Edit: Does virtualdub work with MKV? The description on here doesn't indicate that it does. It lists about everything except for MKV. Previous to this I was using some lame editing program that came with my camcorder to do this (ArcSoft Media Impressions) but it does not support MKV.
Edit 2: Also tried ImageGrab but it does not support MKV either.Last edited by zdvd; 7th Mar 2010 at 01:18.
Modify playback speed of .mp4 video and or .flv and save.
By jsvez2010 in forum Newbie / General discussionsReplies: 0Last Post: 16th Sep 2011, 19:18 -
Digital Frames / Video Playback?
By therock003 in forum Portable VideoReplies: 3Last Post: 24th Jun 2009, 12:13 -
a good tool for joining dvd vob files (which make up one single video) to g
By extent in forum Newbie / General discussionsReplies: 20Last Post: 23rd Jan 2009, 14:00 -
How to remove a single or more frames from a DVD
By justmehere in forum Authoring (DVD)Replies: 2Last Post: 22nd Apr 2008, 13:06 -
Single video with multiple simultaneous audio playback
By vhdmi in forum EditingReplies: 0Last Post: 27th Dec 2007, 16:50
