I recently downloaded some torrents of a tv show. They have 10 shows each and the total size is 3.47 g. They were mpeg4 files. Using Easy DVD Creator, I added the 10 files.
They were converted to .vob (audio_ts and video_ts), but the message came up that there wasn't enough room for the files and it did not burn the DVD.
Do mpeg files get larger upon conversion? I am trying to burn these shows to send to my daughter, who does not get this channel with her satellite.
I cannot afford to purchase another burning program. Can you please help me?
	As a general rule, you can fit between 2 - 3 hours of downloaded material to a DVD when converting to DVD video. The more you try to put on, the lower the quality. You can do things like resizing to half D1 to fit even more on, but the quality will take a hit. While there are no absolutes, my rule of thumb was 3 45 - 50 minute episodes, or 6 25 minute episodes, depending on the source quality. if the source quality was high, I might only put two episodes to a disc.
 So put less per disc, and you will get a better outcome. Get your authoring program to create the Video_TS structure on your HDD, then burn to quality media with Imgburn.Read my blog here.
  burning DVD from either .VOB or .mp4 filesBy rosmari in forum DVD RippingReplies: 6Last Post: 16th Apr 2012, 12:56
  Burning VOB files to DVD WITHOUT Menus Or ChaptersBy mediachimp in forum Authoring (DVD)Replies: 5Last Post: 11th Aug 2010, 02:11
  Converting DVD(.vob)files to ONE fileBy LouieLand in forum Video ConversionReplies: 14Last Post: 10th Feb 2010, 03:58
  Converting PAL VOB FILES TO NTSC VOB FILES...By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
  HELP! DVD Burning VOB files doesnt workBy liam0114 in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2007, 18:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
