I am using Adobe Premiere and Encore.
In Encore, NTSC DVD field order is set to lower and can't be changed.
The source is from Canon AVCHD, which Media Info shows as TPP (upper).
The encoder has a choice for lower or upper, with lower as the default.
How would this affect the video quality? Does the encoder simply shift one frame to convert upper to lower?
thanks!
If the video is interlaced and you get the field order wrong, it'll play horribly jerky. Believe me, you'll know it.
Shift? If I'm understanding you correctly, cutting out a frame won't change the field order. The encoder just sets a flag that says in what order the fields are to be played. If you get it wrong in the encoder you can change the field order afterwards using ReStream.Does the encoder simply shift one frame to convert upper to lower?Last edited by manono; 7th Mar 2010 at 03:53.
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
MPEG2HD to DVD Conversion – Field Order
By miepel in forum Video ConversionReplies: 13Last Post: 20th Dec 2009, 23:14 -
Field order for PAL DVD
By PeskyJ in forum Authoring (DVD)Replies: 3Last Post: 29th Dec 2008, 21:59 -
Field Order When Converting HD source to DVD
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jan 2008, 02:22 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14
