I have found it realativly easy to convert a sequence of stills to MPEG1 using TMPGenc.
My question is, how do you do this for MPEG2? This breaks down into almost two separate questions:
1) The frame rate question, ie for PAL the images have to be "served" at 50Hz, how do you "fool" TMPGenc into then interpreting every second field as either a top field or a bottom field and produce a sequence of frames at the correct 25Hz rate
2) the pixel displacement problem, presumably, each image (gif, bmp or jpg) has to be displaced by +/-1 pixel relative to its predecessor. Will TMPGenc synchronise automatically the top/bottom field order.
Has anyone tried this? I'm considering doing this to create an interlaced test pattern to test bench MPEG capture cards, and I'd like to create a SVCD to play on a DVD to source video into the test capture card. I am considering creating the hyperbolic zone plate test pattern using Mathematica or Matlab. At least it would form an independant test source we could all use.
Thnx in advance
PN
Results 1 to 1 of 1
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 23:09 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 10:16 -
Are they fully hdmi spec amplifiers if they are only 5.1 instead of 7.1?
By yoda313 in forum AudioReplies: 8Last Post: 10th Aug 2009, 22:03 -
fully hd,hdmi,hd ready
By gunukhan in forum DVD & Blu-ray PlayersReplies: 3Last Post: 31st Jul 2007, 14:14 -
keep interlaced footage on tmpgenc xpress
By kamaleon in forum Video ConversionReplies: 2Last Post: 6th May 2007, 10:31
