Hi!
I am searching for PAL-M tuned lcd television sets (22 to 26") that will work in Brazil without the need to hook up an external converter. I found every possible other tv sets that will tune every other system possible but PAL-M.
Your leads will be welcome.
Thanks!
Why can you not just buy in Brazil? That would seem ideal to me.
This company sells a lot of CDs, DVDs, books, electronics, etc. in Brazil. I've mail ordered CDs and DVDs from them with no problems.
http://www.livrariasaraiva.com.br/
They sell TVs. I'm not saying you're going to get a bargain this way, but since you seem determined to go about this the difficult way they might be able to help you. You'll have to know Portuguese to really get anywhere on the website though and I can't promise you that they will ship TVs to the USA. I have no idea what their policy is for electronics. Many electronics vendors have very restrictive international shipping policies. Amazon UK, for example, won't ship ANY electronics, not even small ones like razors, outside of the UK and maybe Ireland. Not even to France. -
Hi, Jman98,
flat panel tvs cost three times as much in Brazil. thanks for the link. I speak Portuguese. -
Try these guys, they are local to me, have an actual store and are very helpful. They have a decent
amount of multi-standard TVs:
http://www.world-import.com/tv.htm -
IMHO: if you intend to stick to the analog broadcast, better use an old and good big CRT
--- LCD displays, only for digital + Hi-Def video.
P.S.: "PAL-M" is just a stupid idea from the dark days of the military dictatorship. Why care about it, now that the Brazilian TV has finally gone into "the digital age" ???Last edited by El Heggunte; 6th Mar 2010 at 21:49.
the only reason I want to stick to a Pal-M lcd is to avoid using an external converter.
PAL-M is 525/60 and unique to Brazil. I doubt you will find a name brand supporting that format outside Brazil. The only hope may be a Chinese or Taiwanese brand that supports all standards from one model design.
Purchase one of these test signal generators to test TV sets in stores. If the TV tuner doesn't support PAL-M, you will see monochrome.
http://www.barrel-of-monkeys.com/graphics/prod/patgen/patgen.shtmlLast edited by edDV; 10th Mar 2010 at 20:19.
http://www.kiva.org/about
how do I REMOVE the v-chip from newer televisions
By lostinlodos in forum DVB / IPTVReplies: 42Last Post: 26th Jul 2011, 01:17 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 14:47 -
best high def televisions for standard definition input?
By EAO in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2008, 15:15
