How do rip you subtitles from a MP4 file?? What's the best way? What''s the best program for this?
Results 1 to 14 of 14
Yamb is not letting me add any video file to rip from. It says drop to it but it won't let me add anything. I used this other program called My MP4Box and it demux a files that is a H264. Is this what I get my subtitles ripped from? If so what do I use to see the subtitles in this file type? Also thanks so much. This forum is the bomb also. Very quick replies here.
What I am working on is redoing a Anime series that had bad english translation subtitles. I found a mp4 video that had the right translations. I figure this would save me more time if I just rip the correct subtitles than having to watch scene to scene and copying the right text and making a new .srt file of it. This way I can just convert the subs from the mp4 file to .srt and just sync the times. This would be much better on my eyes also. LOL
How can you tell if the subs are hardcoded? Here is one example of one file I'm trying to rip the subtitles from http://rs307l32.rapidshare.com/files/274618592/Saint_Seiya_The_Hades_Chapter_Inferno_-..._Courtroom.rar . I could do word for word from this video since the translations are perfect. My next project is to sync it with VOB file. -
Using this program I got this info.
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 54.3 MiB
Duration : 24mn 29s
Overall bit rate : 310 Kbps
Encoded date : UTC 2009-08-27 07:58:17
Tagged date : UTC 2009-08-27 07:58:17
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : avc1
Duration : 24mn 29s
Bit rate mode : Variable
Bit rate : 275 Kbps
Maximum bit rate : 1 415 Kbps
Width : 840 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.028
Stream size : 48.2 MiB (89%)
Writing library : x264 core 56 svn-680
Encoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=5 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=275 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Tagged date : UTC 2009-08-27 07:58:19
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : Yes
Format settings, PS : Yes
Codec ID : 40
Duration : 24mn 29s
Bit rate : 32.0 Kbps
Maximum bit rate : 35.8 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 5.61 MiB (10%)
Encoded date : UTC 2009-08-27 07:58:19
Tagged date : UTC 2009-08-27 07:58:19 -
Yes, it looks like the subtitles are hardsubbed, since there's no mention of a subtitle stream. That means you'll have to do it the hard way (you can't demux them), so you'd have to OCR them - have another program attempt to read/guess the characters in the subtitles from the video. I don't have any experience in doing that, though, so I'll leave it to someone else to cover.
If cameras add ten pounds, why would people want to eat them? -
If the encoder is as incompetent as it appears from this, I suspect this is a re-encode of a release by some other (more skilled) group. Look for an MKV source instead, which should contain softsubs.Encoded date : UTC 2009-08-27 07:58:17
Writing library : x264 core 56 svn-680 -
Hardcode subtitles into a MP4\MKV file
By uncivil002 in forum SubtitleReplies: 18Last Post: 12th May 2015, 05:16 -
How to watch an mp4 with subtitles in a .srt file
By Robor in forum Newbie / General discussionsReplies: 0Last Post: 9th Jul 2011, 07:47 -
How do i extract subtitles from a mp4 file please?
By davidsama in forum SubtitleReplies: 2Last Post: 22nd Feb 2011, 19:06 -
How do you rip subtitles from a DivX file w/4 subtitles
By JoeBolden in forum SubtitleReplies: 2Last Post: 21st Nov 2007, 15:46 -
Adding subtitles to a MP4 file?
By Sokesleezy in forum SubtitleReplies: 5Last Post: 24th May 2007, 01:56
