I have a bunch of movies as .avi files which I would like to burn on a DVD so as to play on a PS3. I read on the Ps3 forums that the support of PS3 for playing .avi files depends on the encoding on them. So I am using Red Kawa's PS3 Video9 to convert them into a PS3 compatible format.
I'll be using Nero 7.5 to burn the dvd. What type of dvd should I burn it as? Should it to be a data dvd or video dvd since nero doesn't detect .avi files in the video cd.
My PS3 plays DIVX encoded avi files, although I have never used it for that. All I'd need to do is burn them off as data and finalize the disc. I have used it as a media server a few times and they played well.
Thanks worked like a charm. BTW which program do you suggest for converting .mkv file to PS3 compatible format? Should i go for vob or avi?
Depends on the quality of the mkv. If it is 720p resolution then I use multi-AVCHD and create AVCHD DVD discs which playback fine and allow for DTS HD audio etc as well.
If it is lower resolution and has only stereo audio then MP4 with AVC/ACC works pretty well.Read my blog here.
Editing AVI type files
By Robertos in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2011, 11:22 -
Playing multiple m2ts files on PS3 from a DVD
By dieselgg in forum Authoring (Blu-ray)Replies: 2Last Post: 20th Jun 2009, 10:47 -
AVI to DVD playing on PS3
By silv in forum ffmpegX general discussionReplies: 2Last Post: 11th Oct 2008, 15:06 -
Problem playing an AVI file on PS3.
By z.ee in forum Newbie / General discussionsReplies: 4Last Post: 13th Aug 2008, 16:58 -
No Video with MKV files advice on playing on a PS3
By edmond in forum Newbie / General discussionsReplies: 6Last Post: 28th Jul 2008, 05:42
