I am interested in a DVR/ dvd recorder with HDD - but it only records in +VR mode.
There seem to be a lack of technical info around the internet about the spec - and I'm hoping someone here can enlighten me.
I believe - but am not 100% certain - that +VR mode refers to the disk formatting itself - not a separate video standard. Can anyone clarify this?
The other differences appear to be how all muxed video/audio is recorded as a sequential vob file(s) instead of one vob / title.
I know +VR is supposed to be reasonably compatible with dvd-video - which means that the disk format and video recording format (mpeg2/aac) would have to be exactly the same.
I know there is an extra folder made
If I have a +VR disc - and copy the VIDEO_TS folder to my computer and make a dvd out of that - would the disc be dvd-video compliant - or are there technical differences in the mpeg encoding as well with +vr?
Thanks,
--Rob
DVD+VR is a subset of DVD-Video.
The DVD-Video standard includes both disc/data formatting requirements, as well as video data requirements.
DVD+VR is the same way, including both.
DVD-Video does not use one long VOB file either. DVD-VR does, however. (Long VRO file, actually.)
DVD-VR and DVD+VR are not the same.
Wikipedia claims that DVD+VR uses one titleset, but that's not my observation. That's just not correct.
Titleset (VTS) and VOB is not the same.
As long as the VIDEO_TS is copied and re-burned with a UDF+ISO9660 mode formatting, it will be fine.
Again, already DVD-Video compliant, being a subset.
All DVD recorders use DVD-VR or DVD+VR.
DVD-VR comes with the added nuisance of "video mode" or the incompatible "VR mode"
DVD-Video was not created with DVD recorders in mind, hence the backwards "VR" hacks.Last edited by lordsmurf; 8th Mar 2010 at 19:14. Reason: disambiguation added
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 08:28 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27 -
Questions about dvd + vr mode
By heman28 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 24th Feb 2008, 17:53
