hi there, a friend recently gave me a heap of quicktime videos which i tried to convert to avi or wmv to make them smaler in file size for computer storage but the problem is now some have a black bar along the right side and bottom of the screen when i play them in real player or vlc player, i dare not convert the rest of them of fear the same problem im unsure what i should do to to fix the ones i have already converted or what to use to convert the rest so they wont end up like the same any advice would be helpful
Results 1 to 12 of 12
How did you convert them? What program(s) did you use, what codec, etc.
Just buy a small external USB drive and save yourself the grief.
"Quality is cool, but don't forget... Content is King!" -
i have tried 2 video converters from the internet, one called free video converter the other any video converter , the code i think is xvid for avi or wmv v9 for wmv not sure what code is the best though or what is the best free converter that wont cause the black bar problem
Quicktime is a container not a video format. What is the video format of these files? Are they uncompressed SD, DV, MPeg, h.264? Are they high definition?
Are these files important to you?
How do you want to use them?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
when i record on my on camera the file ending comes out as .mov which is a quicktime file, i just want to watch them on any player without having that annoying black bar long the bototm and right side when i shrink them down for computer stoage -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Problem with QuickTime - DV Format
By parisisal in forum Software PlayingReplies: 3Last Post: 10th Mar 2009, 09:56 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
DV to a format that play in QuickTime and standaloneDVDplayer with chapters
By DavidCasillas in forum MacReplies: 3Last Post: 20th Sep 2008, 21:28 -
MKV to any Quicktime-supported format - for Mac
By brijazz in forum User guidesReplies: 2Last Post: 8th Aug 2007, 17:07
