Hey all, just recently my JVC DR-MH20S died, does nothing but flash loading, and I am looking to buy a replacement but having a hard time finding all I need for £300 or less, with good ratings and a good brand.
Main features I am looking for:
Built in Freeview tuner for recording Freeview
A clock that sets itself
A channel guide with easy selection of programs to record and a way to record programs up to 2 weeks in advance (as far forward as video+ codes usually go)
If a program changes schedule because of previous program running late, I would like it to adjust accordingly.
Ability to start recording something, and begin watching it before the recording has finished (this is a must).
Ability to watch a DVD or watch a recorded program from the library while recording to HDD (also a must).
Series link would be nice but not essential.
Ability to play back DVD-R discs, photo discs, the usual etc.
1080p upscaling.
Also, Freeview reception is a little flakey, but TV has a built in signal booster which cures that, do any HDD DVD recorders have one?
I think that is all of it, basically what my JVC did + the good new stuff without an ugly useless menu system.
I have found one that I think has most of that, with ok ratings, the Toshiba RD329DT for £299 at John Lewis (RD329DTKB on Amazon for £209, not sure of the difference), but would like opinions and suggestions of others to look at, £300 is pretty much the limit, but may be able to stretch that slightly.
Another I looked at was the Panasonic DMR-EX89EB-K, which is rated pretty good but that is getting expensive.
Thank you
not sure about the brit models....hard enuf to keep up with american and canadian
you may want to try those international model sellers
they should have a panasonic or pioneer that may do the trick, but I can't swear to it, sorry.
Reading HDD from HDD recorder on Windows XP
By mvidelgauz in forum Newbie / General discussionsReplies: 12Last Post: 18th Apr 2011, 02:51 -
Copying from standalone hdd recorder's hdd to pc hdd
By flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 06:17 -
DVD Recorder With HDD
By siddiqir in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th Oct 2007, 01:44 -
PC HDD Driver for Panasonic DVD Recorder HDD
By SG-01 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 30th Aug 2007, 03:54 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
