Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I had e-mail TDK tech support about being able to overburn an 80+ & 80++ CDs to 90 & 99 min (respectively). They said it could be done using Nero (which I have) but he also mentioned that it may damage the CD writer
    Does anyone have any extra info on this ? I just go the CD writer and wouldn't want to break it the first week.
    I understand that overburning passes design specs but is it the design specs of the burner or the CD- media ?
    thanks for any help
    Paolo
    Mar 2002
    New Jersey
    I wouldn't attempt it, unless someone else on here has had other experiences. TDK gets very upset about things. LOL
  3. Max overburn on the TDK is about 89 mins.
    Between 1-3 mins should not cause any problems
    When you get upto 88-89 mins you are reaching the very edge of the laser writing area so may cause problems in writing.
  4. I have a TDK Velo cd-writer 16x 10x 40x, I have had it for almost a year now and have burned a few 99-min cd's with no problems. also 80-min
    cd's overburned with no problems.
