Hello. I have an HP Elite Laptop 6930p that I use for work. I use a docking station and run dual 19" monitors. The problem is, the docking station has 1x VGA and 1X DVI port. The monitor that has the VGA cable - resolution sucks complared to the DVI. Is there a solution where I can run DVI to both monitors and have it be a true DVI signal?? Seems this should be common place these days. But I am finding out it is not. So I come to a video editing/ help forum because my assumption is this is a community where 'fuzzy' graphics/ display is not acceptable. Any help is appreciated.
Results 1 to 10 of 10
something like this
http://www.digitaltigers.com/sidecar.asp--
Wow. Yep, this would do the trick. These units are pricey. Never expected them to be that much.
Matrox has some similar items that are a bit more affordable.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815106011&cm_re=matrox-_-15-106-011-_-Product -
There are also USB2 to DVI-I display adapters that can be stacked for multiple displays.
Good for non-gaming desktop display.
Sample
http://www.newegg.com/Product/Product.aspx?Item=N82E16815306014&cm_re=USB_DVI_display_...-014-_-ProductRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
valvehead//
you used to be able to add a second vid card to a laptop via pcmia/expresscard slot to get a second dvi, but they seem to have gotten scarce.
ibm & dell also used to have "advanced" docking stations available with pci/e slots for additional cards. haven't seen one of those in a while either.
High end laptops still have pcmcia card slots but most people buy the low end models. Those rely on USB2 accessories.
SEEKING Dual HDMI +DVI PCI express card
By kctobyjoe in forum DVB / IPTVReplies: 9Last Post: 3rd Jan 2011, 19:03 -
Output to a 3D TV via dual head DVI hardware + existing laptop scrn
By rjamesd05 in forum EditingReplies: 16Last Post: 28th Jun 2010, 02:51 -
using dual displays with tmpgenc 4.0 xpress
By buckethead in forum Newbie / General discussionsReplies: 1Last Post: 30th Mar 2009, 22:54 -
Dual displays: how to display same on both?
By Quimbly in forum ComputerReplies: 10Last Post: 22nd May 2008, 21:48
