im having some problem buring vcds, i tried using NERO, but everytime i try burning a vcd it gets half way through and i get a error that says this cd is not cd recordable??? Im using brand new memerox cds, i also trie Kensiko and got the same messgae?? any ideas??....also would it work to use my cd creator and burn the VCDs and data??? any input would be helpful...or IM me Russdmb15 if you can help
thanks
russ
