Hi, just reformatted my hard drive and reinstalled windows 7. Downloaded virtual dub and ffdshow. I know they are both installed correctly because I'm able to use VD and I was able to go into the VFW configuration settings of ffdshow and tweak it. The problem is that the ffdshow codec doesn't show up when I try to compress a video in the video compression settings of VD. What am I missing?
thank you
Under 64 bit Windows: 64 bit applications require 64 bit codecs. 32 bit applications require 32 bit codecs. The two don't mix.
virtual dub não abre arquivos cokm codec xvid
By sandroguchilo in forum AudioReplies: 3Last Post: 14th Dec 2010, 16:43 -
ffdshow codec in VirtualDub
By funky honky in forum EditingReplies: 2Last Post: 23rd Jun 2010, 11:53 -
virtual dub xvid codec encoding w/o profile
By caner12 in forum EditingReplies: 7Last Post: 5th Jul 2009, 12:08 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 17:47 -
New codec integration in FFDShow
By werner77 in forum ProgrammingReplies: 0Last Post: 26th Nov 2007, 16:39
