hi guys...i have just purchased the wd tv hd media player.i plugged in my external hard drive that i have loads of movies and music on but it won't play any of them.the movies are images of my normal dvd,s.can anyone tell me the best program to use for converting my files to use on the wd tv hd player please.can it play the whole dvd structure or is it best to have just the movie only???i also don't really want to lose quality on the conversion.i have clone dvd that i use too.
also i have mp3 music on my external hard drive but again they wont play.the wd keeps searching but nothing happens..any ideas??many thanks for you help...cheers
	WDTV cannot read ordinary DVD structures. It can read an .ISO file, or individual .VOB files or many other codecs like .mp4. You need to rip your DVDs as a single VOB file for best results, or use .ISO. If you use the usual factory VOB structure, you will notice a pause or break between files. Naming gets to be a problem also.
 You have a bit of work ahead of you. Either rename ALL of the VOB files or make an .ISO file out of what you have. You cannot get menus or chapter marks in either case.
 I have no clue as to why your mp3 files do not play. Perhaps they areat an unsupported bit rate.
 Bob A
	Moving you to our dvd ripping section.
 I thought iso images worked on the wd hd. See http://www.avsforum.com/avs-vb/showthread.php?t=1101848
	To repeat, ISO files DO work on WDTV. You just don't get menus or chapter points. Special features I am not sure about.
 I had some problems with the firmware that came with my WDTV and they were solved when I updated. I strongly recommend this.
	The WD is not reading your external drive for some reason.
 There are two threads on the WDTV depending on which unit you have...
 https://forum.videohelp.com/threads/311266-New-WD-TV-Live-(WDTV-v2)?highlight=WDTV
 https://forum.videohelp.com/threads/296845-Western-Digital-HDMI-USB-Media-Player-(WDAVN...highlight=WDTV
  Video/audio TS files convert to an uploadable MPEG videoBy Prizm007 in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2011, 15:30
  HELP! I can't convert these video files!By joeyc in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2009, 23:59
  HELP! how to convert video ts files to imgBy underoath in forum MacReplies: 2Last Post: 14th Nov 2008, 07:32
  I want to convert some video files that I have so I can burn them to cd.By jbenjack in forum Newbie / General discussionsReplies: 16Last Post: 22nd Jan 2008, 15:45
  I Cannot Convert/Rip WM Video Files?By Lennoxtown in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2008, 07:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
