I need to convert videos while maintaining the best possible quality. I do not want to change any settings - same size, aspect ratio, frame rate, etc. I want to convert from one format to another without any noticeable loss of quality. I am converting for projection on a large screen, not for showing on an ipod.
Inputs need to include MOV, MPG2, and AVI (DV). Outputs need to include MPG4 (H.264) and WMV.
There are A LOT of video converters out there, but any I have tried so far are geared towards ipods and such and while they may have a preset for good quality, it's usually not good enough and the quality loss is noticeable.
Results 1 to 30 of 46
The quality will never be improved so why are you converting?
Conversion to MPG4 (H.264) or WMV will be lossy. I've seen few projectors that even take those formats.
Got a model number for that?Last edited by edDV; 4th Mar 2010 at 23:20.
http://www.kiva.org/about -
Some more details: I am projecting from computer using Media Player Classic 6.4.9.1. It's old, but it still works more consistently than any other player I've tried. It does have its quirks, though. It doesn't play HD MOV files worth a damn, even with Quicktime Alternative codec. But then Quicktime on the PC doesn't do so hot with HD files either. Some film makers will encode files at ridiculous bitrates like 40 megabits per second that apparently play fine on their $5,000 Macs. I kid you not. So any MOV files I get I have to convert. DV AVI files can sometimes be problematic, so even if they appear to play fine I prefer to convert those as well. Basically AVI and MOV files are containers, not true video formats, so they can contain some strange things sometimes. Lastly I can play most MPG2 files just fine, but the HD MPG2 files (rare, but I do get them) can be problematic and are humongous so I want to convert those too.
I'm not really concerned with file size. There is a "point of no return" beyond which if you keep upping the bitrate the video doesn't get any better because it can't get better than the original, so file size shouldn't be an issue if the "highest quality" preset is set at the appropriate HQ bitrate for each file type (which admittedly not everyone agrees on).
BTW, I am using the CoreAVC codec, which allows MPC to play all forms of MPG4 files without any trouble. WMV also plays without any trouble, thus those are my output files of choice when working with anything above DVD quality. I have been able to save these formats from fancy editing packages without noticeable quality loss, so I know it's possible, but I don't want to use a jackhammer to do the job of a toothpick.Last edited by madmartian; 5th Mar 2010 at 00:45.
Rewrapping won't fix a 40mbps file. However, admittedly I hadn't considered that before. How would one "rewrap" an MOV? Or an AVI? Computer specs are decent - core 2 duo with midrange graphics card and Windows 7.
sure it can help in some situations ,
e.g. if it's h.264 in mov. You could use dxva to decode, or even coreavc which you have. What is the file type? another situation is xdcam in mov, where the splitter on windows isn't set up properly when it's in mov container. xdcam with it's audio streams is close to 40Mbps
You could use ffmpeg to rewrap some or (yamb to mp4) , but it depends on what the input format is, again use mediainfoHowever, admittedly I hadn't considered that before. How would one "rewrap" an MOV? Or an AVI? Computer specs are decent - core 2 duo with midrange graphics card and Windows 7.
.mov is just a container, it' s important to identify what is inside.
Sometimes it's as easy as switching splitter or decoders or players. More information on the files would helpLast edited by poisondeathray; 5th Mar 2010 at 15:12.
I get new files all the time, so it's not just for one specific file. I just need a program that will convert with a "maximum quality" setting instead of trying to save disk space.
If you're content with converting , some options were already listed
"Maximum quality" would be lossless. x264 does offer that mode, but your filesize will be huge.
Just use a low CRF value like CRF14-16 and it will be close to visually lossless on playback
In order for MPCHC to work, it has to be setup correctly. You can use DXVA to decode some streams (graphics card)
Good luck -
I tried matching settings in MPC-HC to the MPC settings. I didn't like Handbrake, but I appreciate the suggestion. What I'm really looking for is something with an interface like "Total Video Converter", but with presets for maximum quality. Unfortunately TVC is geared more towards converting files for small devices.
Never seen these problems. What version of MPC-HC do you have? MPC-HC is almost updated dailly here: http://www.xvidvideo.ru/media-player-classic-home-cinema-x86-x64/
MeGUI is being updated again (make sure to switch the update sites in MeGUI to the Dev site option to get the latest versions). I use MeGUI to do quick encodes to h264 (many profiles to choose from). I use HCenc for mpg2 stuff.Last edited by thymej; 10th Mar 2010 at 18:57.
To be perfectly honest with you, on a projection screen, nothing is going to beat running the video through an ABT or Reon or HQV upscaler and video processor. For display, I've long since given up on trying to encode to some latest and greatest format. Just send the video in as raw a format as you can to a BD player (that can stream) or a receiver (with upper end scaling hardware) and you get some pretty amazing results in large screen sizes.
True, but the video has to play - on a computer through player software. The theater does have a line-doubling projector, so even interlaced DVDs look surprisingly good, but HD looks better when I can get it into a format I can play.
VLC can't do multithreaded H.264 decoding, so it sucks for playing high-bitrate HD H.264.
MPC-HC, KMPlayer, etc. are better (and MPC-HC can do decoding with DXVA), plus they will rely on ffdshow/CoreAVC/whatever H.264 decoder you have installed.
I don't think it's very fair to immediately assume something is wrong with the code itself when other people have no trouble with it. Did you get a buggy build or something? What's your version? Try another from poisondeathray's link, or try another player...Originally Posted by madmartian -
>> Learn what the files are.
Not sure of your point or how it relates to the topic. I can drop files into Gspot or MediaInfo until I turn blue - that doesn't change anything. I specifically ask for certain file types and get something completely different - mainly because a large portion of users don't know how or aren't technical at all. They may not even know what an MPG or VOB file is - they only know that their Final Cut program on their Mac spits out a file and then they send it to me. As long as I have a program that can convert anything to formats I know work well, it's not an issue. I am looking for the best program for that purpose. "Maximum Quality" is not fictional at all. The problem is that most programs are geared towards more compression and saving disk space. Take "H.264 Encoder", for example. It has a "high quality" setting, but drop the file into MediaInfo and it's clear they opted for a low bitrate, even at "high quality", in order to save disk space. One more setting at a higher bit rate and that program might be all I need. No I won't reach perfection - "no quality loss at all" is indeed fictional for any re-compression - but what I have experienced thus far cannot be classified as "good enough". -
This is the problem. Fix it.They may not even know what an MPG or VOB file is - they only know that their Final Cut program on their Mac spits out a file and then they send it to me.Want my help? Ask here! (not via PM!)
Yah, tell me about it! If I could fix that, I would be the subject of scientific experiments.
Tell them what to send you, teach them what to do.
Yah, I tried that. Even gave detailed instructions on how to extract a VOB file from DVD. I still got MOV files.
My first look at MeGUI is that it does way more than I need and is a lot more complex than I want it to be. I really do want something as simple as drag/drop source file, click on target format, click on MaxQuality preset, click on Start. Making the quality settings editable would be nice as well, but I hope I don't have to use that. That's kind of what Total Video Converter and AVS Video Converter do, but they are geared towards small size files. It's possible if I tweak the settings enough one of those might work, but I think the trial period is already expired on those. The interface is almost the same on the two apps. -
It looked like WinFF was going to be the answer. It has a "Super High Quality" preset. It converted one MOV nicely, but my hopes were dashed with two failures. It couldn't handle two of my input files - one an MOV and one an HD MP2 file. Other programs can handle those two files, just not with high enough quality output, so the blame goes to the software, not the video files.
AVS Video Converter 7.1 Quality Problems
By toulsonguk in forum Video ConversionReplies: 0Last Post: 1st Jul 2011, 12:28 -
MPEG II Video Quality drops using Any Video Converter...
By Spoilerone in forum Video ConversionReplies: 9Last Post: 10th Feb 2011, 11:30 -
MTS converter for best quality
By Luka38 in forum Video ConversionReplies: 4Last Post: 8th Apr 2010, 07:36 -
bad quality of camstudio recorded avi video merged by avs video converter
By shimi in forum EditingReplies: 5Last Post: 25th Feb 2010, 15:33 -
Fast Video Converter - quality of output?
By tonyp2 in forum Video ConversionReplies: 2Last Post: 13th Dec 2009, 15:08
