Pegasys Inc. continues to add WTV input support to their TMPGEnc product line with the release of the latest free update for TMPGEnc Authoring Works 4. Revision 4.0.9.37 adds Windows Media Center WTV file input support so users can import their live TV recordings and turn them into a DVD, DivX Ultra, or Blu-ray Disc.
The program allows users to edit video footage with an easy-to-use cut-editor, create a custom menu and then output and burn the project to DVD or Blu-ray Disc. Smart Rendering technology won't re-encode video compliant with the output format.
This update is free for current users. New users can try the free trial version or purchase the product starting from US $59.95.
This update is currently for the English language version only though the German version will most likely be updated in the near future.
Product webpage:
http://tmpgenc.pegasys-inc.com/en/product/taw4.html
Revision history:
http://tmpgenc.pegasys-inc.com/en/download/taw4_rireki.html
Results 1 to 1 of 1
TMPGEnc Authoring Works 4 input 264 not working
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 18th Sep 2011, 09:51 -
TMPEnc Authoring Works 4 Problem with input AC3 Audio (5.1 channels)!!!
By JackyWang in forum Authoring (DVD)Replies: 10Last Post: 22nd Jun 2011, 10:46 -
Does Tmpgenc Authoring works 4 support motion background menus?
By perfection in forum Authoring (DVD)Replies: 1Last Post: 10th Mar 2011, 02:35 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGEnc MPEG Editor 3 updated with WTV input support
By gyoshi in forum Latest Video NewsReplies: 0Last Post: 3rd Mar 2010, 19:34
