I need a mpg divider software. I have to cut my MPGs into small parts so i need a divider for it. VCDCutter divides it but all the files are in 1MB.
Does anyone know such a program which can divide the big MPG's into small parts?
it would be great appreciated if you answer my question. I couldnt find any prog..
Regards.
Kotuadam
Yep, its called a "Calculator" what it does, is... you type in a number and it divide by "number" and the results are used to cut up the mpeg
Sorry,
Well you use the Merge and Cut in the Mpeg tools in TMPGenc, select ADD from merge/cut and add your movie, click edit and slide the bar to the right to give you the time of the movie. (If you don't already know)
1:45:12 = 60+45 =105 Minuets 105/number of cuts.
Now move to the end frame of the first cut and select } as the end, save this chunk (Run) and continue with next.
If you can do it without a "Calculator" you wont get better results, but you will feel smarter
Did I say sorry, oh yes I did...
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 17:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
