Hello,
I am trying to convert a DVD to MP4.
I am having problems converting DVD's that I used DVD shrink to rip.
1st I use VOB2MPG
2nd I use SUPER to convert to MP4
3rd I copy it over using PSP Video 9.
Every time I copy over the video to my PSP it tells me file not recognized.
Not sure what I am doing wrong. I even tried using Handbrake but that gives me a different error. After converting the video it will not play right.
I have tweak the setting on both SUPER and Handbrake and I am not sure what I am doing wrong.
Any help would be much appreciated.
I'd rip the disc(if it's not copy protected too badly) with DVDDecrypter - IFO Mode - File Splitting NONE first.
Then....Load it up in AviDemux and output it to Xvid/Divx from there.
I'm not sure the exact properties for PSP....you should be able to match it....maybe. -
Are you sure you're placing the converted videos in the correct folders on the PSP? I believe the PSP's rather picky about that. (I don't remember which videos go where, though, sorry.)
As I recall, when you're using the PSP preset in SUPER (you probably shouldn't change anything after you select that preset - as I mentioned, the PSP does tend to be picky), it also places the output video in a folder with the same name as the folder it should be placed in on the PSP - though I don't remember if it includes the entire directory tree (as empty folders) when it does that.
I also don't remember if PSP Video 9 tells you where the video should be placed... but I thought they also had a 'library' feature that would attempt to copy the video to the correct location on the PSP?
AVIDemux has a PSP preset, as well (Auto > Sony PlayStation Portable). I haven't tried using it, though. (Haven't encoded anything for the PSP in ages.) Don't see why Sony can't just add DivX/Xvid support for the PSP...If cameras add ten pounds, why would people want to eat them?
XVID4PSP -- what are the best settings to convert ripped VOB files to PSP?
By WaverBoy in forum DVD RippingReplies: 5Last Post: 15th Nov 2014, 11:09 -
Is there a simple way to convert a letterboxed h264 video to avc mp4 psp?
By yoda313 in forum Video ConversionReplies: 2Last Post: 22nd Jul 2010, 18:13 -
.VOB to PSP-Movie issue. Certain won't convert
By egmadayag in forum MacReplies: 5Last Post: 23rd Oct 2007, 15:14 -
How do i convert multiple VOB files at 1 time using PSP Video 9
By mac7654321 in forum Video ConversionReplies: 1Last Post: 22nd Sep 2007, 06:59
