Hi, I have multiple ISO images that I want to burn to one DVD. They are all videos (contained in the ISO images), so I would also like to have a menu in the beginning of the DVD.
I tried researching about this and I a few people mentioned extracting the ISO images and re-author them into one big ISO image and then burning it to a DVD. But could I have a menu?
Thanks.
Results 1 to 11 of 11
you would have to make your own menu. dvdauthorgui/dvdauthor might work, but you'd have to design and author it. another choice might be to buy convertxtodvd. in any case you you would need to extract the files from the iso's first. winrar or isobuster are a couple that can do that.
I have quite the same situation. I have 7 dvd's with 7 movies (some with subtitles) and I created an ISO for each with DVD Shrink. Now I want to create a DVD-Video with a menu to compile the 7 movies still including th subtitles. Can I do that on DVD Shrink?
How do I do that?
Thank you! -
shrink doesn't make menus.
Yes I want a DVD-Video so the person will see it can choose between the movies, go back to the title menu, play it all, etc.
I know that I can manke it without the menu on dvd shrink but that's not what i want. :/ -
although it is payware, dvdremake pro allows the user the option to merge 4 dvds int one disc with full menus and such.
In your case you can merge 4 of them into one and export that disc, then import that newly made disc and do another merge with the remaining 3
however you would have to extract the video_ts folder from the iso files since remake does not import iso's directly.
Multiple Titles In A DVD ISO To A Single AVI
By Simmons in forum Video ConversionReplies: 1Last Post: 9th Aug 2010, 00:32 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 16:29 -
Want to combine several ISO files onto one DVD. Want a menu.How?
By DRScott in forum Authoring (DVD)Replies: 2Last Post: 4th Jul 2008, 07:53 -
DVD from ISO has no audio (except menu does)
By KraftDinner in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 18:53 -
Burn a cd iso to dvd?
By jimminy_kriket in forum Newbie / General discussionsReplies: 6Last Post: 4th Jul 2007, 00:41
