I have an old Pentium 3 desktop collecting dust and was wondering if it would be powerful enough to capture HD streams so I can playback on my PS3. From what I have read you don’t need nearly the CPU to capture as you do to playback so I thought I would ask… Most of the capture cards I have looked at recommend a P4.
I hear the current rate of capturing ATSC is about 5 gig an hour. I think this is using MPEG-2 though. If I could find a card that could capture in Divx or Xvid then I could record hour long programs without having to chunk the file up into 4GB sections(or rencode).
This is probably a lot to ask of a Pentium 3 but maybe the right video card could help me out with this?
Maybe I just get stuck with capture cards like this?
http://www.digitalconnection.com/products/video/mdp130.asp
It looks like this can do what I want with or without a good video card, but recording high def is over 8GB an hour. It also stores HD streams in a .tp file extention, and I don’t know if the PS3 will play them without conversion.
Here is another one that says it needs DXVA on the video card. Also 8GB per hour.
http://www.digitalconnection.com/products/video/fusion7rt.asp
				Results 1 to 10 of 10
	old Pentium 3 = no
	ATSC tuner cards tune the desired subchannel (e.g. KABC-DT 7.1), extract in hardware the MPeg2 program stream and associated AC-3 audio and export via the PCI bus to hard disk. The CPU activity for this is minimal so long as the picture isn't previewed during capture. Preview or playback is heavy on CPU+GPU but a modern GPU will take near the full HD MPeg2 decode load when the player is properly configured.
 If not monitoring, it should be possible to stream from an ATSC tuner to a hard drive with a small CPU so long as the OS meets tuner card system requirements (e.g. XP SP3). The data stream is 19 mb/s (~3MB/s) maximum which is less than DV format.
 As far as transcoding from MPeg2 to h.264 in real time, a Core2 quad core probably can't keep up without heavy quality loss.
 There are no ATSC tuner cards that do MPeg2 to h.264 conversion on the fly but there is the hauppauge HD-PVR that converts HD analog component from your cable tuner to HD h.264.
 If you move to Europe, you will find some DVB TV stations streaming h.264.Last edited by edDV; 3rd Mar 2010 at 17:05. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	ATSC tuner need Pentium 4 2.0 Ghz is bear min as long you get a good Video card as in AGP ATI 36xx or nVidia 66xx for playback
 The HD-PVR bear min Pentium 4 2.4Ghz with ATI 3650/3850 in AGP or ATI 4650 in AGP for playback and you want a min of Memory Interface 128-bit
 As far as transcoding that need lot's hosepower forget the Pentium 3/4 your better off building a new system
 I think the PS3 dose support .ts try download a few ts clips file and steam to your PS3.
	If you don't display the video while capturing a P3 will work with most ATSC or QAM tuners. In that case all the software is doing is saving an MPEG transport stream to a file. The trick is finding software that doesn't insist on displaying the video while it's being captured.
 Viewing and converting is another story. Conversion can be done on a P3 (if it has sufficient memory) but it will be horribly slow.
	If I recall, with the Hauppauge cards / devices and WinTV (the provided software) if you pause WinTV it pauses the display while still capturing the stream. Correct me if that isn't so, SHS.
	There is more information on the MyHD MDP-130 here: http://www.hdtvtunerinfo.com/myhdmdp130.html
 It can display video without using the computer's VGA card.
	If you use scheduled PVR software (not WinTV) the stream capture is done as a background process (no preview).
 This may be possible with WinTV Scheduler. I haven't tried it.Recommends: Kiva.org - Loans that change lives.
	GLE3 should forget the idea of any kind of preview, playback or format conversion on a PIII computer. It is only good for scheduled recording with PVR software where no conversion is performed.
 If the PS3 is incapable of direct playback of a 3 to 19 Mb/s MPeg2 program stream with AC3 audio, then another faster computer would be required for playback, commercial edit and conversion.
 Alternative 2 is capture from an HD cable box to an h.264 file with an Hauppauge HD-PVR. Still, a separate faster computer would be required for playback or to edit out commercials.Recommends: Kiva.org - Loans that change lives.
  Minimum System Requirements for capturing miniDVBy darkwhite in forum ComputerReplies: 19Last Post: 27th May 2012, 08:21
  Newbie Hardware requirementsBy multistream in forum Newbie / General discussionsReplies: 0Last Post: 23rd Nov 2011, 11:39
  Minimum System requirements for Bluray ripping/burning?By orbital517 in forum Blu-ray RippingReplies: 12Last Post: 28th Oct 2010, 12:32
  Minimum PC Requirements to do HD Video Editing?By dan1st in forum Newbie / General discussionsReplies: 5Last Post: 9th Jul 2009, 19:29
  Minimum system requirements to play 720p files?By ukb007 in forum Newbie / General discussionsReplies: 11Last Post: 21st May 2008, 14:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
