    Sep 2008
    Alright, I've been converting avi files for a while now using Avi2DVD. It does all the authoring and can place it into a iso file. However it's extremely slow. I converted a avi file the other day using Winavi and it was extremely fast. First problem is that it's one file. I need it split into chapters. Second problem is I tried to use Imgburn to make an iso image from the vts/vob files. It burned, but doesn't play on all players. When using Avi2DVD I've had no problems with iso's playing on any player. Trying to burn the Video TS folder using my burning program results in a playback limitation on my dvd player. If anyone can help me I would appreiciate it. Don't know if I'm missing steps or what.
    Try convertxtodvd or the free dvd flick or avstodvd.
    And when you burn a VIDEO_TS with imgburn, check https://www.videohelp.com/guides/burn-single-layer-dvd-s-with-imgburn-id1164#1164 so you are doing it correctly.
    Sep 2008
    Thanks for the reply. I will try these to see what I come up with and let you know.
