I've been using this with no problems. Now, I'm trying to work with an mpeg2 file and after using dvd2avi to create a project, I get the following error whien I browse to the audio file :
cannot load cpuinf32.dll, mplapx.dll, cannot locate files........
I was able to find a copy of the cpuinf32.dll file and it now just lists the mplapx.dll in the error. I've been unable to find this file.
Thanks so much for all the help, Guys.
it sounds that you have same strange audio decoder so try change the priority in tmpgenc under enviortmentl options->vfapi,
try increase the directshow reader or the vfw reader to change decoder/reader
I found a copy of the file on the net.
http://users.hoops.ne.jp/tscbucho/mplapx.dll.zip -
I had the same problem and now have both of the missing DLL's..
Email me if you need them , and i will send ..
leon.judge@ntlworld.com
Need aacenc32.dll & aac.dll for be light
By tofuguy in forum AudioReplies: 5Last Post: 30th Oct 2011, 19:58 -
TMPGEnc Write Error's of module 'P3Package.dll'
By manicradio in forum Video ConversionReplies: 0Last Post: 29th Dec 2010, 18:55 -
NUVTwain.dll missing Hauppauge 150
By CyberWoolf in forum Capturing and VCRReplies: 4Last Post: 12th Nov 2009, 08:19 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 15:34 -
Missing Sensapi.dll File.....Need Some Help!
By RKelly in forum ComputerReplies: 2Last Post: 31st Jul 2007, 17:20
