I have started digitizing my VHS collection, and encounter the following issue:
I capture in MPEG-2 with my Ion VCR2PC. I can open these MPEG without problems in VLCplayer and jump to any point in the movie.
Due to the quality of capture from VHS, I wanted to apply filters to clean up the image before burning the movies to DVD. I apply the filters in VirtualDub and frameserve to TmpgEnc 2.5 (registered version).
It is with the output of TmpgEnc that I have a problem.
I can open the output movie in VLC player and it plays fine. But if I want to navigate in the movie, I only get sound and no image any more (the last image just keeps being displayed).
I thought that it was a problem with the filters, but even if I framserve the source movie without applying any filter, the problem stays the same.
If I demux the output movie from TmpgEnc, I can open the m2v in VLC player, and in that movie, I can navigate to any moment in it. So I tried to re-mux the output from TmpgEnc. I remuxed the output m2v with the mp2 taken from the source file, and that video kept having the problem of not being able to navigate in it. If I remux the m2v taken from the source file with the mp2 from the output file, there is no problem with navigating in the movie.
Based on advise I found on this site, I tried Womble Mpeg Video Wizard. By just making a full copy of the movie, I finally got an mpeg-2 in which I could navigate to any point (and confirm that the filters did a good job). The file has the exact size as the TmpgEnc output, so I don't even have an idea what Womble might even have
changed about the file.
So it looks to me that something went wrong with the output of TmpgEnc.
Output settings are:
- mpeg-2;
- Automatic VBR (CQ_VBR);
- Maximum bitrate 8000 kbps
- PAL (same as input source)
- 720 x 576 (same as input source)
- Interlaced (same as input source)
Does anybody have an idea what I might have set up wrong in TmpgEnc?
This is most likely a problem of incompatible MPEG splitter and MPEG decoder on your system. Not a VirtualDub it TMPGEnc problem.
DebugMode frameserver output: RGB24, RGB32 or YUY2 ?
By codemaster in forum EditingReplies: 8Last Post: 6th Jan 2011, 14:09 -
DVD-r Footage menu wont navigate ! Re- Author ?
By rockonvidtrade in forum Authoring (DVD)Replies: 2Last Post: 3rd Oct 2009, 18:42 -
How can I change titlesets on a dvd to be able to navigate like chapters?
By chello378 in forum Newbie / General discussionsReplies: 3Last Post: 6th May 2008, 00:29 -
Navigate video dvd in WMP
By dynamique in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2008, 09:45 -
Mpeg-2 conversion with TMPGEnc: output too bright
By Novie in forum Video ConversionReplies: 10Last Post: 23rd Nov 2007, 11:31
