I have an HP Pavilion Entertainment PC and am using Ulead VideoStudio 11.5 plus. I have been using this software for a few years and have made many video files and DVDs - some long (like an hour) some short. I have never had an issue with rendoring before now. I am working on my "2009 family video" - it is about 1 hour 20 minutes. When I set everything up to begin the render and burn, the system shows that I have enough memory to perform this task. However, the system keeps shutting down (at different percent completes each time) without any warning and without any error messages.
I've tried cleaning up my hard drive - which I don't think is the problem since the software shows me that I have enough memory - any suggestions? I'm not sure what to do at this point!
Thanks!!
Check your CPU temps while rendering. Your CPU fan has probably filled with dust and is no longer cooling the CPU effectively.
http://www.kiva.org/about -
thanks! I'll definitely check out that link! Is there a way to clean the fan? Or do I have to replace it?
You can clean it. Vacuum out all the dirt.
ULead VideoStudio 9 Burning Error
By pcork23 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jan 2011, 10:39 -
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 09:27 -
ULEAD VideoStudio trim
By dcmoser1952 in forum EditingReplies: 3Last Post: 24th Feb 2009, 15:43 -
Ulead VideoStudio 11 on Vista
By run1492 in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 18:21 -
Audio problems with Ulead VideoStudio 8
By beanosirra in forum Newbie / General discussionsReplies: 4Last Post: 14th Jun 2007, 10:35
