HELP!!!!
I captured video with VirtualDub 352x480, using PICVideo setting 18. I cut unwanted commercials and added filters (not smart de-interlacer). Then I frameserved with VitualDub to TMPGEnc.
I found the *.vbr.avi file, loaded VCD NTSC template, settings at High Quality, then started. TMPG timer says that it would take 24 hours to encode. Should be that long? What am I doing wrong?
Thanks.
Tmpge always estimate xxx ouers.
Try to cut the avi-file down to 5-10 min.
Framserve it, an let i go.
When Tmpge is finished, the used time will show how long it has been working.
Now can you estimate the real time for your whole avi-fil.
dilbert
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 08:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 07:15 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23
