Howdy all,
A friend sent me a link yesterday and I became extremely intrigued: http://www.michaelmarantz.com/motion/phish.html . Does anyone know how to string photos together or edit a movie so that you can create this delayed type of effect?
I assume there is a program out there that allows you to separate frames from a movie, but maybe someone can enlighten me on the subject. Thanks!![]()
Step 1 : Take lots and lots of photos in relatively quick succession
Step 2 : Load as an image sequence in Vitrualdub or After Effects or Premiere etc
Step 3 : Save as video
You could use an avisynth script to kill off every nnn frames, then play with the frame rate to try to recreate the effect from an existing video. It may take several passes to remove all the frames required.Read my blog here.
You might also have some luck searching for the term time-lapse (photography), and maybe stop-motion animation as well. (Not sure about the latter, but I mentioned it because you did use the word 'delayed.'
Create own Subtitles
By kerpal in forum SubtitleReplies: 11Last Post: 16th Oct 2013, 10:19 -
How to do they Create Motion in this example
By Thread7 in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2012, 16:17 -
How to create a bitstream?
By krao in forum Newbie / General discussionsReplies: 0Last Post: 16th Oct 2009, 18:16 -
create slideshow
By shashgo in forum Newbie / General discussionsReplies: 27Last Post: 14th Aug 2008, 12:13 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36
