It looks like the calls for a Sizzle tutorial in the sticky weren't realized. I started another thread about a problem with Toast when multiplexing various VOBs or MPG files using the Video Tab. I have tried Sizzle as an alternative but I can't get my Disc Image to play. The Start Movie button on my menu lights up when I click it but the DVD does not actually start.
Here is what I have done, which obviously is not correct:
1. I click Add title and add my first MPG file. I repeat the process to add my second MPG title.
2. I have a Start Movie button and using the Edit button>dropdown to Action: Jump to beginning of disk. However, my disc image, when mounted with Toast does not actually start the DVD.
3. I select Save Disc Image
Can someone walk me through the steps of using Sizzle so I can end up with a playable DVD?
My archived copy of Sizzle 0.5b2 is from 2003 (copyright notice) or 2004 (file date). Seven years is a long time in software land. I'm surprised the tool is still in use, given how basic it is. I doubt anyone is willing to go through the trouble of research to write a tutorial now, for so few users, when there are more complete authoring tools.
I think this creates a very short loop without actually getting to any content:Originally Posted by danielmak
Beginning of disc > TOC menu > button > Jump to beginning of disc > TOC menu > button > Jump to beginning of disc > ... (repeat)
Try a editing a "Pick a clip" button to: Jump to menu... > Title 1.
Then in the Title 1 menu, set a "Play clip" button to Jump to chapter > Chapter 1 (00:00:00.00)
Yes this will create a double menu, but it will work and you will be able to test if this fixes your playback issue.
(You could 'clean it up' with MyDVDEdit, by skipping a menu, if Sizzle works as you hope it does.)
I doubt Sizzle will fix your issue, as I think the problem may be with your MPEG, and not in the authoring. -
Thanks Case. Before I follow this through. Can you also tell me what I would do in MyDVDEdit to skip the menu?
BTW my MPG is fine. I was able to burn in UDF mode on LiquidCD (another old program) and the DVD played fine on my set-top player. The problem with this is that the MPG files are burned on their own (no VIDEO_TS folder via multiplexing), which means the DVD won't play on the computer (a problem if I trade the DVD for another soccer DVD). The problem is clearly one with Toast, but why this is happening now and why I seem to be the only person having this problem is a big mystery. As I noted in the other thread, the problem is not just with one MPG but any MPG or VOB burned in Toast's video tab setting.
My first stab with Sizzle produced a DVD that played fine on the computer after I screwed around with MyDVDEdit but the DVD would not load on my set-top DVD player (the loading icon just continued to spin--hence my request for your advice about what to do with MyDVDEdit since I obviously did something partially right to get it to play on my computer but not fully right since it didn't work on the set-top). -
just a tip with myDVDEdit:
- open the resulting VIDEO_TS folder in myDVDEdit,
- go to the "allowed regions" (from memories: middle bottom part of the GUI, check the vertical tabs)
- uncheck regions 7 & 8 (a lot of home dvd players refuse to read the disk if theses special regions are enabled)
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
Dealing with VOBs, subtitles, Sizzle and Miyu
By silverspell in forum MacReplies: 4Last Post: 25th Feb 2009, 06:57 -
How do I do this with Sizzle (dvd authoring tool)?
By master_debator in forum MacReplies: 0Last Post: 27th Aug 2007, 13:45
