On which line? There's no script that I'm running. You either run it from the command line or drag a .mp4 onto it's shortcut icon. In either case there's no way to keep the resultant popup cmd window open long enough. Once you get back to DOS prompt, the window has already gone. The pause will have to be put by the author in the program source code.
Results 31 to 36 of 36
Use a batch file. Something like:
Change the path to mkvmerge.exe. And you may need to add more options to the mkvmerge line.Code:"G:\Program Files\mkvtoolnix\mkvmerge.exe" --output %1.mkv %1 pause
The thread mentions several programs. How am I supposed to know what you're using? In any case, using a batch file with "pause" will leave the window open until you press a key.
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 02:43 -
Looking for ts to mp4 conversion tool
By joel5632 in forum Video ConversionReplies: 15Last Post: 3rd Dec 2015, 05:49 -
MKV to MP4 without conversion
By swiego in forum Video ConversionReplies: 9Last Post: 7th Dec 2014, 12:54 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
AppleTV - Conversion of MKV to HD MP4
By Austehn in forum Video ConversionReplies: 7Last Post: 22nd Oct 2008, 20:28
