Hey All,
This ismy first time posting so go easy on me if the answer is obvious.
I have been asked by a friend to take a look at the only copy of his wedding video.
It is in the form of a video_ts folder with the relevant .vob .ifo files.
When played back some of the .vob files appear as a thin vertical strip some others appear to have the same image repeated 6 times accross the screen during playback.
I have tried converting them to another format like .avi but it just reproduced the errors (as expected)
i don't know what information might help you so i will post some GSpot details below:
dar - 1.333
par - 1.067
sar - 1.250
720x576 - 4:3
Hopefully this can be fixed by someone not a noob like me![]()
Hey,
Thanks for the quick response! i patched the files with ifoAR2WS and now all of the files are having the same issue. it seems like the picture is repeated 6 times along the horizontal axis. After pacthing non of the files are super tall and thin anymore (however i have kept a copy of the old files aswell).
The menu structure works fine and the video backgrounds work fine aswell its just the clips that are wrong.
here is a series of images showing the problem.
Menu working fine:
http://davermills.com/wp-content/uploads/2010/03/menu.gif
Multiple pictures of problem clips:
http://davermills.com/wp-content/uploads/2010/03/problem.gif
http://davermills.com/wp-content/uploads/2010/03/wedding_encode_error1.gif
BTW this issue was occuring on the only DVD copy of this film which i have taken the video_ts folder from in hopes of fixing.
How to fix long VOB seek times
By aliasx51 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Apr 2008, 13:02
