Anyone have experience with MKVextractGUI 1.6.4? I want to demux a Matroska video *.mkv to convert and remix it; sound and subtitles came out okay, but the video stream *.h264 is jerky. Any idea how to avoid that?
Or can you suggest a better demuxer for Matroska videos?
djc
Try demux with tsmuxer.
And if it wont work then give more info like
Are you just playing the h264? or playing it after you remuxed it to? to what then? mkv?
Are you using mkvextractgui with latest mkvtoolnix? -
most media players , source filters and splitters cannot handle raw avc streams. Put it in a container
If you are converting it, leave video in the mkv container for the conversion (no reason to demux, which can remove delays and cause sync errors) -
I'll try tsmuxer. Thanks for the tip.
Yes.
Just playing the pure *.h264 video stream as extracted, not remuxed. djcv -
Problems with MKVextract
By carlmart in forum Video ConversionReplies: 6Last Post: 29th Sep 2011, 08:52 -
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
mkvextract gui not extracting h.264 viddeo stream
By kurian in forum Video ConversionReplies: 13Last Post: 21st Feb 2011, 11:14 -
mkvextract for osx
By scarlac in forum MacReplies: 0Last Post: 14th Jul 2010, 04:54 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27
