I guess you can call this a continuation of:
http://www.tacticalgamer.com/hardware-software-discussion/157809-distorted-sound-fraps.html
Because no one could help me.
Every time I try to record game play the sound is distorted. An example is below, I apologize for your ear drums.
http://www.viddler.com/explore/WanderFreeForev/videos/6/
It was suggested that I alter the volume of Stereo Mix, however, I can not alter it. For some reason I can only mute it. Even from Windows sound manager.
ID:	622Click image for larger version
This distortion occurs even with hardware acceleration set to none and sample rate converter lowered. I have uninstalled and installed codec packs only to find the same distortion.
I have run out of options here. I have no clue how to diagnose and correct this problem. Can anyone help me?
Info:
Windows XP pro
