  1. Sorry if an answer to this has already been provided but I'm unable to find one.
    I use Pinnacle 14 Ulitmate and am making a DVD with mulitiple menus. One master menu with 4 options - 1 to play entire disc, the other 3 to navigate to 3 sub-menus that list around 8 - 10 chapters in each of 3 sections of the movie.
    My problem is that if I set "return to menu" at the end of each chapter, then I can't make the "play entire disc" play right through the movie - once it reaches the first "return to menu" marker it returns to the sub-menu.
    Is there some way I can play the entire disc, but still automatically return to a menu if I've selected an individual chapter?
    Hope this all makes sense.
    Many tahnks fro ma newbie to this forum
    Feb 2004
    Australia
    Well you might compile the project to output folder and include a "play all button" which has no link
    Load the resulting output into pgcedit and use the "play all" function to generate a new title which can be linked to from the "play all" button
    Test playback and adjust nav commands as required ... there's a few guides about covering nav command funtions
