I'm an old regular here but i haven't posted much but i'd like to know something. i bought Windows 7 and Vista had DVD Shrink files in Program Data,but in 7,they seem to be under a new directory or something. Can someone help me find these files? thanks.
Are you talking about the output from DVD Shrink ? You set this in the preferences or when you hit Backup
Read my blog here.
no i mean i don't even see a program data folder where the analyze files are.
i create a folder called ProgramData in Preferences? i never did that before. show me how.
What exactly are you looking for ?
Are you looking for the output to DVD Shrink (i.e. the ISO file or Video_TS folder) ?
Are you looking for the analysis files ?
The output goes where you tell it to go. Check what is says when you hit backup and it will tell you where it is putting it be default. If you don't like that location, chose a new one.
Program Data was just a default location under Vista. Windows 7 also has Program Data, but it is a hidden folder be default. To see this folder, click on Organize -> Folder and Search Options, then click on the View tab. Click on Show Hidden Files, Folders and Drives and Program Data will become visible.Read my blog here.
question about dvd shrink
By marlo in forum Authoring (DVD)Replies: 5Last Post: 29th Aug 2010, 05:22 -
Hello I'm New & I Have A Question About DVD Shrink 3.2
By taffy1967 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 05:28 -
DVD Shrink and Nero Recode question.
By siratfus in forum DVD RippingReplies: 8Last Post: 13th Jan 2010, 22:49 -
DVD Shrink compression method question
By SCDVD in forum Newbie / General discussionsReplies: 5Last Post: 14th Jan 2009, 13:42 -
question regarding analyze in DVD Shrink
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2007, 09:31
