Hello,
Can anybody tell me how to create a message at the end of a svcd movie "End of Disc 1". Thanks for your time and effort
DixLon![]()
Hi,
One answer, is to use a video editor/creation program (you could try MovieXone, as it's freeware) to write and or draw the text you want.
Alternatively, if you want a moving 3D image - things like Xara 3D will also output AVI files.
Next have the program render your desing into an AVI file - then encode to whatever (S)VCD standard you are using with TMPEGenc, etc.
Once you have your MPG, you can either join it to the end of your movie or write it as a separate file if you are using menus.
Hope that makes sense! -
thanks Corkey,
I will try your suggestion and see how it goes
DixLon
Could not perform end of Disc-at-once
By smt16 in forum DVD RippingReplies: 1Last Post: 18th Jun 2010, 06:50 -
Could not perform end of disc-at-once on dual layer dvd only
By Subhash in forum DVD & Blu-ray WritersReplies: 20Last Post: 25th May 2009, 14:09 -
Why do my DVDs become corrupted at the end of the disc?
By NBninja8 in forum MediaReplies: 16Last Post: 16th Nov 2008, 15:54 -
By mrjoetoff in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2008, 14:27 -
Error: Could not perform end of Disc-at-once - Please Help
By patrickj0781 in forum ComputerReplies: 7Last Post: 20th Jun 2007, 20:28
