I am using Premiere as editor on 1920x1080 30i source. Want to export DVD for my parents. There is a widescreen (720x480, 16:9) option in Adobe Media Encoder.
What's the best practice in producing DVD from HD source?
How does hardware DVD player play back widescreen DVD on HDTV? Does it stretch the video to fit the width?
Thanks!
I've had some luck (finally!) with AVStoDVD ouputing to "DVD Folder Structure" after processing with ClownBD. I'll try from BDRebuilder to see how that works soon. I tried several other programs with varying success but they all want to further compress to approx. 2gb. AVStoDVD gave me a very nice quality 4.3gb that has standard DVD files that play fine on my standalone DVD player. It uses Quenc or HCenc for the encoding (I like HCenc, similiar quality but faster encode).
I love children, girl children... about 16-40
W.C. Fields -
Which version Premiere?
What is your authoring program?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Ideally you would go from AVCHD _x1080i 16:9 to 720x480i (wide) for DVD.
Premiere CS4 will import AVCHD and edit as an AVCHD 1080i project. Then you can downsize to 720x480i internally (not so good) or externally with avisynth. Then you encode 720x480i MPeg2 and author your DVD.
Alternate methods,
2. Cineform digital intermediate format (faster and better resize).
3. Smart bob deinterlace to 1080p/59.94 (best done externally).
4. Import AVCHD to a 720x480i project (quick and dirty).
5. Premiere deinterlace to 1080p/29.97 (quick and jerky).Recommends: Kiva.org - Loans that change lives.
Does a simple AVCHD authoring program exist like DVD programs?
By Killer3737 in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Sep 2011, 12:16 -
Need help by authoring/Burning AVCHD DVD (multiAVCHD/ imgBurn)
By benji179 in forum Newbie / General discussionsReplies: 0Last Post: 4th Apr 2010, 18:20 -
Searching Freeware for DVD-AVCHD (mini Blueray) Authoring
By benji179 in forum Newbie / General discussionsReplies: 5Last Post: 30th Mar 2010, 14:17 -
the best setting for encoding and authoring hd to make a avchd dvd-r and bd
By LEONESVIZZERO in forum Authoring (Blu-ray)Replies: 3Last Post: 8th May 2008, 08:22 -
DVD authoring w/ progressive source - changing flags
By echo1434 in forum Authoring (DVD)Replies: 4Last Post: 30th May 2007, 12:49
