Ok I opened up my divx file in virtualdub and I know i must save to a wav file and combine the wav and the video in tmpeg. Now the problem is that when I open the video file in virtual dub I get this message that the virtualdub has detected an invalid VBR encoding and that I must convert the audio to an uncompressed wave file and then recompress with a constant bitrate encoder. If I save to a wave from virtualdub and then combine the video and audio in tmpeg I get to 62% and then get an invalid audio error. Can anyone tell me what I need to do with the uncompressed wav file to make it compatible?
The crash is probable freeze frames, and not audio problems.
Downlaod "vdub-mp3-freeze.exe" and scan for freeze frames, it makes a log so you can delete bad frames (at keyframes).
Then start your convertion as normal.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
DivX question
By didikai in forum Newbie / General discussionsReplies: 11Last Post: 18th Jun 2008, 21:22 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 24th Feb 2008, 00:35 -
Divx converting question
By KilinKind in forum Video ConversionReplies: 2Last Post: 15th Jan 2008, 19:25
