Hi,
I am looking to get a camcorder to use for reviewing products on my website. Budget is small: Ideally $150 or less. For this reason I'm looking at the flip UltraHD, although it doesn't seem to do well in low light and has no image stabilization at all.
Are there any other alternatives or should I just go with the flip?
Thanks!
Consumer cameras never do well with low light.
Tripod mount yourself.
DV cameras are under $150, but for simple web videos, it may be too much work.Want my help? Ask here! (not via PM!)
Flip, a minipod, and a light source
"Quality is cool, but don't forget... Content is King!" -
For doing product reviews, Flip UltraHD would be great - it has enough zoom to frame what you need and ease of uploading.
Here are three others with similar form and function that you may want to check out.
Kodak Zi8
Creative Vado HD
Samsung HMX-U10 -
Honestly, any of these flips would work: http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2F...reative=390957
Flip tripod: http://www.amazon.com/gp/product/B000VJRUKS?ie=UTF8&tag=thdifa-20&linkCode=as2&camp=17...SIN=B000VJRUKS
Since quality is never going to need to be archival, a Flip works fine.
It's one of the few times I'd suggest or okay one of these.Want my help? Ask here! (not via PM!)
Need Suggestions for a good Camcorder with great sound quality
By techspark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 8th Apr 2011, 11:34 -
Preserving image quality from flash camcorder to dvd?
By rsud in forum Authoring (DVD)Replies: 7Last Post: 19th May 2010, 16:57 -
PVR-150 poor tv quality
By kaptwan in forum Capturing and VCRReplies: 3Last Post: 21st Aug 2008, 15:15 -
Best Quality VCR for Transfering (under $150)??
By adameep in forum Newbie / General discussionsReplies: 7Last Post: 9th Mar 2008, 21:38 -
Hauppauge 150, good or bad?
By SerbianBoss in forum Capturing and VCRReplies: 21Last Post: 4th Dec 2007, 09:24
