  1. Member Tbag's Avatar
    Mar 2006
    My sister has a Advent 5421 laptop running Vista Basic and is painfully slow and is always crashing.
    I recently installed Windows 7 on my Sony Vaio which had Vista HP and found the drivers pretty easily on the Sony website so I was going to install 7 on the Advent only to find that it is much harder trying to locate the drivers for it.
    Anyone have or know where to find the drivers for it? I think this is the official site which is rubbish tbh http://support.thetechguys.com/layout.aspx?ID={f97fce86-d7d4-4778-9f0b-bb956980e0d4}&CatID={cff92421-3f0b-4dd2-ac60-853c71ab1a2f}
    I just heard about driver backup softwares, they extract the drivers from you machine for you to put onto disk for you to use after the new OS intall.
    Is it too good to be true? Can someone recommend a good one?
    Feb 2004
    Australia
    For driver backup and restoration you can try drvback
    Free or make a donation
  3. Gamer and Builder HotDamn!'s Avatar
    Nov 2009
    ps, it sounds like your sister's laptop has a bad hard drive.. just to be sure I would do a drive check once you get Win7 installed. When you install the new OS the partition should skip the bad sectors of the drive so that may fix it, but to be sure I would run a drive scan. Good luck
