I have tried so many ways but not getting the menu I want. Maybe it isn't possible with this software?
I have 6 TRACKS but trying to not have all those have their own menu page.
Looking to see if it is possible to have -
----- TITLE (Play and Track menu)
-------- TITLE 2(from clicking Track Menu) - (List all tracks and choose and play from there - not goto another menu)
Do I need to set up clips differently during source input ?
Should I have only created ONE TRACK and just keep on 'ADD FILE' from that point?
Results 1 to 10 of 10
This software is very template-heavy. You really can't do much outside the few options it gives you.
If you're open to MUCH BETTER software, that's still as easy as TAW4 to use, look into using Ulead DVD Workshop 2, currently only $49 from B&H -- a freakin' steal, seeing how this pro software once cost $500.
If you'd like to keep suffering through the limited options in TAW4, let me know. If I get some time, I'll see what sort of workarounds might be possible. Honestly, the better software solves your problem for not much effort, and just a few bucks. Your menu options are very advanced with DVDWS2.
Read the guide for using Ulead DVD WorkshopWant my help? Ask here! (not via PM!)
Thanks for the reply. Much appreciated.
I have used their software so long I guess I just stuck with it.
It seemed like easy steps for the most part so ... I get comfortable I guess.
But I am willing to try something else that has the same feel.
I will give Ulead DVD Workshop a go and see how it feels. -
TMPGEnc authoring is mostly good for menu-less discs. If you want menus, it's just so rigid, and it does poorly with a few things (font visual quality, for example -- no anti-aliasing appears to be done, and that looks like crap). The fact that it's $99 compared to $49 for DVDWS2 isn't helping it either. TDA used to be cheaper, and now it just feels so overpriced for what little it does. If you want rigid templated menu work, you could use SVCD2DVD for less cost.
But even then, DVDWS2 comes with some nice menus to choose from, should you want a template. And those are really customizable, too -- not at all rigid.Want my help? Ask here! (not via PM!)
Thanks for the help
If you do get time though maybe you could help me out with my original problem? Since I already have everything almost finished anyway but the menu I want.
I will be trying out DVDWS2 before I buy though just to see how it feels but have the feeling ( why I try before buy ) that my system might not handle this software
Just note that the demo limits some things -- like no AC3. The full version has no such issues.
Hmmmm.... it used to not allow AC3 on the demo. It still might not. You'll find out once you start trying it.
Well I guess it does have limitations ...
Most of those are not an issue right now but DD is seeing as I am inputting HD source files ... but I guess I am just seeing how menu creation works anyway so ...This Trial Program has the following limitations:
- The Motion Menu feature is limited to 30 seconds.
- Maximum of 30 menus for one project.
- Maximum of 10 slideshow or video titles for one project.
- Maximum of 99 images for one slideshow title.
- Maximum of 20 chapter points for one video clip.
- No support for Dolby® Digital audio files.
- No User Guide in PDF format included.
- Less content included.
- No utilities and drivers included.
- Ulead offers no warranty or technical support for any trial programs. Ulead does provide a forum where you can get answers to your questions promptly.
- Please take a look at the product documents for help getting started.
You need to have your videos encoded before authoring -- regardless of software.
TMPGEnc Authoring Works 4 Menu Help Needed
By VOYAGER2009 in forum Video ConversionReplies: 1Last Post: 15th Apr 2011, 13:37 -
TmpGenc Authoring Works 4 - Motion Menu Question
By blazin-j in forum Authoring (Blu-ray)Replies: 3Last Post: 18th Oct 2010, 11:00 -
TMPGENc Authoring Works 4 - motion menu no audio
By mobie29 in forum Authoring (Blu-ray)Replies: 3Last Post: 16th Jul 2010, 17:32 -
Menu question re: TMPGEnc Authoring works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 9th Jun 2010, 08:32 -
TMPGEnc Authoring Works 4 Single Menu
By Sakuya in forum Authoring (DVD)Replies: 3Last Post: 22nd Dec 2009, 03:04
