    Feb 2010
    canada
    Hi,
    I have an issue that has been bugging the heck out of me. When I try to demux dvd's, it seems as if the results leave me with two streams of different length. On this one dvd, the AC3 audio track is 5 seconds longer than the video. The dvd plays perfectly in sync, but the individual files are different times. This has been messing me up because I'm trying to time subs to a dvd, but the subs come out messed up because the demuxed audio track is not the same runtime as the dvd.
    Thanks is advance!
    How do you demux ? what app? 5 seconds sounds very much. I would try pgcdemux if you aren't already using it.
    Feb 2010
    canada
    Hi!
    I've tried DVDLab pro, pgc demux, and a couple others. It's about 4 1/2 - 5 seconds longer, but the dvd plays perfectly in sync.
    Thanks!
