I have copyed 2 vob files to my computer when i convert them to wmv files using prism video converter i get a message that the timestamp is in error and i should manually specify a framerate. I changed the framerate from 30 to 25 and reconverted the file, part of the file will play correctly and 12 +minutes will not show anything. This happened each time, before I reconverted, and after. How can I fix this and recover the missing video. I don't think it is corrupted because it plays in it's entirety in the camera.
Just try convert with something else, like winff, xmedia recode.
And if you are converting from a dvd try use vob2mpg to create a single mpg from the vob files. Then convert the mpg.
Error message! Help!
By XAPHSNYC in forum MacReplies: 6Last Post: 8th Feb 2010, 14:05 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Video Stutter / Skip when coverting from DVD to VOB / MPEG2 file
By afs_nj in forum MacReplies: 2Last Post: 13th Jul 2007, 15:39 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
