    Feb 2010
    Brazil
    Hi,
    I have same AVI, WMV videos with the resolution higher than 720x480, which is a DVD supported resolution, and I would like just resize the videos, without converting. Virtualdub does, but I have to convert in the end, Does anybody knows a software for that ?
    Thanks and sorry my bad english !
    It's not possible without reconverting.
    Feb 2010
    Brazil
    Thanks !
    So, I will have to buy a WDTV or mount a HTPC, But both options are very expensive here in Brazil, believe me.
    I have a lot of MKV and WMV files, but converting it all is not god for my PC´s health.
  4. Asus EeeBox?
    http://usa.asus.com/product.aspx?P_ID=wH1q2VTqyLXaCw1f
    How much is the WDTV in Brazil? They run about US$99 in the USA.
  5. Originally Posted by JOHNINA View Post
    Hi,
    It is really impossible to resize the video in any formats without converting it. As I know, if you need to resize any video clip, what you have to do is convert it to another format.
    Feb 2010
    Brazil
    Asus EeeBox?
    In Brazil the WDTV costs a little more than a minimum salary, besides is very hard to find.
    And if I import the taxing is 60% of the price.
    Apr 2004
    Miskatonic U
    You don't have to convert them to another format, but you do have to re-encode.
    Read my blog here.
