Some background.
I have 2 Lite-On ATAPI DH20A4P burners installed. They both read/write audio CDs, they both read/write DVD-R's, and they both will BURN DVD+R's, but neither will READ them. For example, I just make a DVD thru Nero of some home video clips on a Verbatim DVD+R. Nero said it successfully finished the project and the disc plays in a standalone DVD player. In fact, all of my +R discs play in a standalone, but not my computer will not read them.
My system is XP SP3, and I only use Verbatim media on single-layer burns.
I have gone thru the sensible steps....checked firmware (current), even uninstalled the 2 drives and the IDE channel they are on. After re-installation, I got the same result.
Anyone else know what could be the problem?
Results 1 to 12 of 12
Discs burnt with IMGBURN do the same thing... I usually create an image with Nero and then burn with IMGBURN -- and right after successfully burning with IMGBURN, the disc cannot be read in the drive.
I have tried probably 30 +R discs in both drives and none of them work. What is crazy is that it has not always been like this. Over the last year I have probably done 200 burns on these drives with +R discs. I have no clue what has changed. -
Reboot. Does it still happen?
I popped in a +R SL and tried to use IMGBURN to read it to create an image and this was the log....
I 18:10:48 ImgBurn Version 2.5.0.0 started!
I 18:10:48 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 3)
I 18:10:48 Total Physical Memory: 3,538,028 KB - Available: 2,897,708 KB
I 18:10:48 Initialising SPTI...
I 18:10:48 Searching for SCSI / ATAPI devices...
I 18:10:48 Found 2 DVD±RW/RAMs!
I 18:10:55 Operation Started!
I 18:10:55 Source Device: [2:1:0] ATAPI DVD A DH20A4P 9P59 (E
(ATA)
I 18:10:55 Source Media Type: DVD+RW (Book Type: DVD-ROM) (Disc ID: MCC-004-00) (Speeds: 4x)
I 18:10:55 Source Media Sectors: 2,295,104 (Track Path: PTP)
I 18:10:55 Source Media Size: 4,700,372,992 bytes
I 18:10:55 Source Media File System(s): None
I 18:10:55 Read Speed (Data/Audio): 12x / 12x
I 18:10:55 Destination File: C:\Image.iso
I 18:10:55 Destination Free Space: 253,303,517,184 Bytes (247,366,716 KB) (241,569 MB) (235 GB)
I 18:10:55 Destination File System: NTFS
I 18:10:55 File Splitting: Auto
I 18:10:55 Reading Session 1 of 1... (1 Track, LBA: 0 - 2295103)
I 18:10:55 Reading Track 1 of 1... (MODE1/2048, LBA: 0 - 2295103)
W 18:10:55 Failed to Read Sector 0 - Reason: L-EC Uncorrectable Error
W 18:10:55 Retrying (1 of 20)...
W 18:10:55 Retry Failed - Reason: L-EC Uncorrectable Error
W 18:10:55 Retrying (2 of 20)...
W 18:10:55 Retrying (3 of 20)...
W 18:10:55 Retrying (4 of 20)...
W 18:10:55 Retrying (5 of 20)...
W 18:10:55 Retrying (6 of 20)...
W 18:10:55 Retrying (7 of 20)...
W 18:10:55 Retrying (8 of 20)...
W 18:10:55 Retrying (9 of 20)...
W 18:10:55 Retrying (10 of 20)...
W 18:10:55 Retrying (11 of 20)...
W 18:10:55 Retrying (12 of 20)...
W 18:10:55 Retrying (13 of 20)...
W 18:10:55 Retrying (14 of 20)...
W 18:10:55 Retrying (15 of 20)...
W 18:10:55 Retrying (16 of 20)...
W 18:10:55 Retrying (17 of 20)...
W 18:10:55 Retrying (18 of 20)...
W 18:10:55 Retrying (19 of 20)...
W 18:10:56 Retry Failed - Reason: L-EC Uncorrectable Error
W 18:10:56 Retrying (20 of 20)...
E 18:11:04 Failed to Read Sector 0 - Reason: L-EC Uncorrectable Error
E 18:11:04 Failed to Read Sectors!
I 18:11:04 Exporting Graph Data...
I 18:11:04 Graph Data File: C:\Documents and Settings\Kevin\Application Data\ImgBurn\Graph Data Files\ATAPI_DVD_A_DH20A4P_9P59_SATURDAY-FEBRUARY-27-2010_6-10_PM_MCC-004-00.ibg
I 18:11:04 Export Successfully Completed!
E 18:11:04 Operation Failed! - Duration: 00:00:08
E 18:11:04 Average Read Rate: N/A - Maximum Read Rate: N/A -
The drive may be giving out.
one last thing to try is change the ide cable...never know it may cure your problem.....long shot but as LS mentions your drive maybe dying...i'm not fond of LITEON drives for burning dvd media...i use them strictly for ripping purposes.
Go ahead and try to clean the laser.
Follow this guide: http://www.digitalfaq.com/forum/showthread.php/clean-dvd-cd-423.htmlWant my help? Ask here! (not via PM!)
DVD Burner sudenly read/writes at less than 1x speed
By Megahurts in forum ComputerReplies: 1Last Post: 22nd Apr 2009, 21:47 -
is the lite on cd-burner toast??
By gentlejax in forum DVD & Blu-ray WritersReplies: 3Last Post: 22nd Feb 2009, 15:02 -
UGH!!!! READ problems again, this time with Sony DVD burner Sata 22x
By Clint Eastwood in forum DVD & Blu-ray WritersReplies: 5Last Post: 15th Feb 2009, 01:31 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 05:49 -
Dvd Burner only reads older dvds, won't read newer ones all the sudden??
By kpaxfaq in forum DVD & Blu-ray WritersReplies: 6Last Post: 28th Feb 2008, 14:11
