Hi. A few months ago I posted about demuxing audio from mp4 and I wanted to find a better solution to extract audio from an mp4 to a wav. While the suggested tool, TFM audio tool works great, I still wanted to find a better solution so I could demux video with the same tool. TSremux is a great tool but only gets me 90% of the way.
My research and googling has lead me to this solution: MPUI (mplayer front end for windows)
I read with the mplayer command line you can extract audio and video with the audio "dumping" to a PCM wave file. That is exactly what I want. But I like GUI's better.
So can anyone show me how to use the mpui/smplayer to DUMP the audio and video with the audio becoming a PCM wav file. I read mplayer can do this. Do you know if the SMplayer/mpui can do this? Or can it only be accomplished in the mplayer.exe command line ?
Thanks for your help.
Whoops almost forgot some important needed info. The mp4 video type is a h.264/mp4 avc (audio is aac) . And the extracted video should be raw h.264 for dgavc. I almost forgot that. I did not want people searching for my old article in the archives. It's been revived twice. LOL
Also forgot to inform the reader that mpui and smplayer are two different programs.
				Results 1 to 1 of 1
	Last edited by Krelmaneck; 27th Feb 2010 at 15:57. Reason: forgot specific details
  Mp4 demuxing: Graphedit ApproachBy Krelmaneck in forum Video ConversionReplies: 6Last Post: 28th Aug 2010, 04:44
  mp4 (h.264) Demuxing: Is it possible to save a step when encoding to ac3By Krelmaneck in forum Newbie / General discussionsReplies: 4Last Post: 28th Jan 2010, 07:04
  Vob file to MP4: Is my tool/approach correct?By bulava in forum Video ConversionReplies: 0Last Post: 8th Jan 2010, 10:23
  Looking for program to remove the front or end of multiple files.By -=SomeThingEviL=- in forum EditingReplies: 0Last Post: 4th Aug 2008, 17:35
  Demuxing MKV Audio with Mplayer QuestionBy Maikeru-sama in forum Video ConversionReplies: 15Last Post: 29th Jan 2008, 08:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
