I'm having trouble with 1080P mkv files lagging when i watch them on my computer. I think my hardware should be able to handle it but now i'm not so sure. I'll post my setup specs at the bottom. I'm using vlc player to play the files. This is an annoying problem so i'd appreciate any help
Specs:
Processor E5200
2gb 800 ram
1gb bfg 9800 gt video card
1 tb wd green 7200 rpm 32mb drive
By "lag" do you mean video stops then starts?
http://www.kiva.org/about -
the audio keeps going but the video pixelates and stops then it will jump forward after about a minute. it does this the whole time
Was the resolution of the monitor/TV and the resolution of the video? VLC has been known to pixelate when your playing a 1920x1080 video on a 1366x768 TV. If you have the right plug-in (i.e FFDshow, haali media splitter, and avisynth) WMP can better handle the task of a similar problem. Your rig seems not to be the problem area. You have very adequate hardware.
Video Lag....HELP
By chump0 in forum Newbie / General discussionsReplies: 2Last Post: 14th Apr 2009, 19:21 -
video seems to lag
By weeleong87 in forum Newbie / General discussionsReplies: 5Last Post: 15th Oct 2007, 06:43 -
B-Frame decoder lag
By demonwarrior in forum Newbie / General discussionsReplies: 0Last Post: 13th Sep 2007, 01:09 -
Video Lag Problems..
By heartbreaker in forum DVD RippingReplies: 0Last Post: 12th Jul 2007, 19:17 -
WMV streaming lag
By Skribbez in forum Newbie / General discussionsReplies: 0Last Post: 9th Jun 2007, 19:08
