I know this generally isn't something that is done. I used to use my phillips 5960 to play files via disc... but there was also the USB option... the problem with USB is that it has a limited bandwidth and sometimes the video studders.
If the usb is rated at 3000 kbps, how can you encode video files to play through it. I thought I had it down when I set max bitrates at 1500 via handbrake and when looking at media info i get Overall bit rate : 1 640 Kbps
This is not true...I have some that are lower and they studder and I have some that are higher like 2064 and they play fine..
The reason i ask is that I have a usb option in my vehicle and my DVD/navigation plays divx/xvid files.... is there a way I can encode the files to KNOW they will play. Is there a setting or a MEDIAINFO option/explaination that will tell me if THIS is greater than 1000 or 2000 or 2500 it WILL not play...because my previous idea of overall bitrate was WRONG...
I am wanting to do this because I have a 500 gig hard drive that plugs into my system and can hold music\music videos\movies... I can do it via dvd disc, but that would be a headache keeping track of all the discs\switching discs
				Results 1 to 1 of 1
  USB for video transferBy TyWelcome in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 6th Jan 2012, 18:55
  Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 02:02
  S-Video to USB ???By PhillT in forum Newbie / General discussionsReplies: 14Last Post: 18th Jul 2009, 09:46
  Is it possible to capture video through a USB 2.0?By brugesnyc in forum Capturing and VCRReplies: 5Last Post: 10th Mar 2009, 12:15
  Video Out through USB?By Brent212 in forum Software PlayingReplies: 3Last Post: 14th Aug 2008, 15:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
