  1. Hi
    Does anyone can recommend me a software that can be use to record phone call into a computer.
    We have one right now but it is really crappy.
    The only spec that would be nice to have is
    -to be able to record 1 phone call per files automatically (stop recording when there is no noise on the phone and start recording when a phone call starts)
    -to be able to keep all audio files recorded locally automatically
    thanx for your help
    ps. I already have the hardware to connect the phone to a computer TLP104
    http://www.dynametric.com/ProductImages/TLP104_107_large.jpg
    Feb 2004
    Australia
    Pci modem = bitware > voice box
    Just about came bundled with every dialup modem ever made and sold
  3. I don't know what that box you bought actually is but it is completely unnecessary. What you need is a called a voice modem, get a decent US Robotics, it will come with software that should work fine. You can have voice mailboxes, music on hold, get fairly fancy.
    A standard modem will also work fine without some of the extra features and possibly slightly less audio quality.
  4. I use that box because the phone conversation I want to record is not from a standard analogic phone but from a Cisco IP Phone
    this is why I need that hardware to get the audio from the phone to the sound card ...
  5. Texan V Bot's Avatar
    Feb 2006
    Can't you use Skype to make the calls and record them with a program like Total Recorder?
    It Started In Texas
    Feb 2004
    Australia
    Ah ... The IP thing , lol ... VoIP
    This is what you should look into > Miarec Solo
    Dose what you need ... starting off at $99 usd for one line
