Hi there,
I am looking for a suitable solution to primarily capture my PC footage on a hardware level.
I already tried software solutions such as FRAPS and Camtasia. They do fine for capturing video tutorials in Windows but when it comes to gaming, FRAPS causes a major FPS drop which makes it difficult to play.
I stumbled on the Hauppauge HD PVR several times now and it seems to be the perfect solution for my capturing needs.
But some points are still unclear:
Is it also possible to record at a resolution of 1280x1024 (as i still use a 4:3 TFT) or am i forced to choose either 720p or 1080i?
If that is possible, i would connect the HD PVR to one of my Graphic Card's HDMI ports.
Would it cause any problems to use the source computer also as recording computer apart from the loss of a little cpu performance (i've read that using another app than the official one to record brings you down from about 50% to almost 0% cpu-usage)
Thanks in advance!
Your recoding option are only 720x480i or p , 1280x720p or 1920x1080i native tv resolution it dose not support vga native resolution
That possable but I have never try it my self, but you have to setup the graphic software to clone the output and you will need adapt hdmi to a component.If that is possible, i would connect the HD PVR to one of my Graphic Card's HDMI ports.
Being the HD PVR is a hardware encoder there should be 0% cpu-usage with video perview off.
Watermark when capturing with Hauppauge HD-PVR?
By rajman in forum Capturing and VCRReplies: 4Last Post: 6th Mar 2011, 15:14 -
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 22:07 -
Hauppauge PVR footage won't import into FCP
By blacklevel in forum Video ConversionReplies: 1Last Post: 25th Aug 2010, 11:25 -
Capturing standard broadcasts on Hauppauge HD PVR 1212 - which settings?
By Emanef in forum Capturing and VCRReplies: 2Last Post: 20th Sep 2009, 09:59 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 03:19
