Hi,
I have used the combination of MakeMKV for ripping blu ray and Handbrake to shrink it. It works fine but recently when I wanted to back up one of my Blu Rays a problem appeared. MakeMKV ripped the file fine but when I went to handbrake to shrink it, handbrake that it may be copy protected/badly mastered or in a format which handbrake does not support. The MKV file that MakeMKV madeis perfect and run without problem the only problem is that it is 24GB. I really need to decrease its size.
Is there a solution to this or do I use another sofftware to shirnk the 24GB into 4-5GB without significant loss in quality.
Best Regards... Ali
It might be because of some codec that handbrake doesn't support. So give more information, what video codec and audio does the mkv has? Identify using MediaInfo.
Or it's better to convert/shrink with Ripbot264 (first rip with dvdfab decrypter or use anydvdhd). -
Baldrick,
Please excuse my ignorance, but how do I exactly tell handbrake what codecs I am supplying???
By the way, this is the media info:
General Complete name : ABC.mkv
Format : Matroska
File size : 23.0 GiB
Duration : 1h 42mn
Overall bit rate : 32.0 Mbps
Encoded date : UTC 2010-02-19 12:46:56
Writing application : MakeMKV v1.4.12 beta win(x64-release)
Writing library : libmakemkv v1.4.12 beta (0.7.7/0.8.1) win(x64-release)
Video ID : 1 Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 42mn
Bit rate : 29.8 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.600
Stream size : 21.4 GiB (93%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio ID : 2
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS Duration : 1h 42mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 24 bits
Stream size : 1.08 GiB (5%)
Title : 3/2+1
Language : English
Text #1 ID : 3 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : English
Text #2 ID : 4 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : English
Text #3 ID : 5 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : English
Text #4 ID : 7 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : French
Text #5 ID : 8 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : French
Text #6 ID : 9 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : German
Text #7 ID : 10 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : German
Text #8 ID : 11 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : Arabic
Text #9 ID : 13 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : Danish
Text #10 ID : 15 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : Dutch
Text #11 ID : 17 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : Finnish
Text #12 ID : 19 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : Hindi
Text #13 ID : 21 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : Norwegian
Text #14 ID : 23 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : Swedish
Text #15 ID : 25 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : Turkish
Text #16 ID : 27 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : English
Text #17 ID : 29 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : French
Text #18 ID : 31 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : German
Text #19 ID : 33 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : Dutch
Text #20 ID : 35 Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : The same subtitle format used on BDs/HD-DVDs Language : English
Menu
00:00:00.000 : en:Chapter 00
00:06:58.292 : en:Chapter 01
00:11:53.546 : en:Chapter 02
00:16:31.740 : en:Chapter 03
00:22:47.908 : en:Chapter 04
00:30:03.218 : en:Chapter 05
00:36:27.935 : en:Chapter 06
00:41:39.413 : en:Chapter 07
00:48:16.393 : en:Chapter 08
00:53:13.607 : en:Chapter 09
00:59:06.292 : en:Chapter 10
01:07:47.104 : en:Chapter 11
01:13:24.525 : en:Chapter 12
01:19:09.536 : en:Chapter 13
01:28:12.578 : en:Chapter 14
01:33:58.341 : en:Chapter 15
Thanks and Best regards.... Ali
how to rip a blu-ray movie to a blu-ray disc
By TURBOLENCIA in forum Blu-ray RippingReplies: 1Last Post: 25th Nov 2010, 16:40 -
Blu-Ray vs BR-Rip
By therock003 in forum Newbie / General discussionsReplies: 16Last Post: 14th Feb 2010, 12:39 -
Can i use a blu-ray reader to Rip my Blu-rays ?
By fairwind in forum Newbie / General discussionsReplies: 4Last Post: 29th Nov 2008, 11:04 -
can i use a blu-ray reader to rip my blu-rays?
By fairwind in forum DVD & Blu-ray WritersReplies: 2Last Post: 28th Nov 2008, 13:08 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
